121 Users Online (120 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door tag lables/parameters
Sun, Jul 9, 2006 at 7:56:12 PM | Door tag lables/parameters
A5Len
I'm a newbie to revit and a current job requires Door tags with the door number over the Room number. As the door number/mark is a standard revit parameter I have no problem however there is no parameter for room numbers and when ever i try to create a parameter, it shows up as a red question mark when loaded into the project. Any help would be appreciated
Sun, Jul 9, 2006 at 8:12:56 PM | RE: Door tag lables/parameters
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You will not be able to have the door tag automatically report what room its associated too using the automated room numbers that revit associates to each room. Unless of course you are right into programming and make use of the API. The questionmarks are showing up red because the shared parameter that has been created for the door tags has not been loaded into the project and associated to doors. Go to settings-->family category parameters and add the shared parameter to doors. HTH.
Sun, Jul 9, 2006 at 8:28:07 PM | RE: Door tag lables/parameters
A5Len
Thanks. The parameter is associated to doors in the project parameter settings. (I assume this is what you were talking about with family catagory parameters) I can now get that info to show up in the doors properties, however it is not visible in the actual tag. any sugestions?
Sun, Jul 9, 2006 at 8:33:40 PM | RE: Door tag lables/parameters
A5Len
Also it would seem it will be created as a shared parameter, is it possible to make it a instance parameter
Mon, Jul 10, 2006 at 1:39:50 AM | RE: Door tag lables/parameters
A5Len
Thanks for the origional advice - I was creating another parameter in the project rather than loading the one i had already created - thankyou for the help, works fine now
Door parameters not scheduling or tagging in double door.
Mon, Sep 26, 2011 at 3:29:50 PM
Create & reference door tag parametrics
Thu, Nov 8, 2007 at 2:24:44 PM
Instance Parameter On Keynote Tag
Tue, Jul 22, 2014 at 11:14:29 AM
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
shared parameters and tags
Tue, Jun 12, 2012 at 2:15:25 PM
Page generation time: 4.1860
