66 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> New to Revit with Dimensioning question
Sun, Jul 9, 2006 at 11:23:28 AM | New to Revit with Dimensioning question
dbruck
I'm trying to dimension for a quadrant point to a quadrant point on two circular walls. Is this possible without some dopey workaround? If not, shame on the Revit folks.
Sun, Jul 9, 2006 at 6:09:24 PM | RE: New to Revit with Dimensioning question
MarieCz
yea it is you just have to start your dimension from something straight/parrallel (like a line or wall) to that quadrant and then continue and dimension all the points you want, and then go back and unpick the the line that you started with and it should be right.
Sun, Jul 9, 2006 at 7:38:32 PM | RE: New to Revit with Dimensioning question
josta
1 Stars: 1 Votes
Just draw two reference planes parallel and lining up with the quadrant points and dimension these; simple! JOHN
John Acosta ARA, Architect
Mountain Architecture, Big Bear Lake CA
Sun, Jul 9, 2006 at 7:45:51 PM | RE: New to Revit with Dimensioning question
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Select the walls and turn on the centre marks if you haven't already. Then simply select linear dimension instead of the default aligned dimension to the lock the dimension string to be horizontal or vertical. HTH.
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:56 PM
Revit 2008 - Dimensioning Curtain Wall
Tue, Feb 19, 2008 at 5:26:47 PM
How do you handle dimensioning not-to-scale stuff in Revit?
Mon, Aug 15, 2011 at 2:30:06 PM
Revit 2010-Dimensioning
Wed, Jan 20, 2010 at 10:47:17 AM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:58 AM
Page generation time: 2.2309
