62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> hiding some walls of the same type
8 Posts No Rating |
can somebody help please, i have a particular wall type in my project and i want to hide only some of the walls so they don't show when i print i have selected the walls i don't want to see and hidden them in the sheet view but they still print. also whats the best way to set up a project so you can isolate wall types to turn off.
p.s. thanks for any reply.
![dduarte Avatar](user_avatar/19192.jpg)
![3 Stars: 2 Votes](/images/stars_3.gif) |
Put the walls you want to turn off in their own workset. Turn off the workset in VG. You could also try Design Options but I haven't tested it yet myself.
Post edited on 2006-07-08 12:35:33
8 Posts No Rating |
thank you for your time dduarte.
![4 Stars: 10 Votes](/images/stars_4.gif) |
If you are using Revit 9 you can use filters.
Macca Sunshine Coast QLD Australia |
Hiding linked Walls by Wall Type??? |
Wed, Oct 12, 2011 at 2:48:13 PM
Hiding walls |
Sun, Apr 17, 2005 at 3:55:24 AM
Demolished walls hiding proposed stuff |
Tue, Sep 20, 2016 at 5:54:34 PM
HIDING FLOOR EDGES ON WALLS |
Fri, May 24, 2019 at 4:00:10 AM
Filled Region <invisible lines> overlapping and hiding surrounding lines |
Mon, Feb 4, 2008 at 10:41:34 AM
Members: | 2017161 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
