Forums >> Revit Building >> Technical Support >> Topo Surface using ACAD dwg
I'm trying to create a toposurface using an imported CAD dwg. I imported the dwg, used the toposurface-from import command, selected the dwg, and it gave all of the contour lines points, but those points were all 0'0". I don't have CAD on my computer, so I can't change the base drawing. Is there a way, within Revit, that I can set the contour heights without having to select each point and give it a height? Also, when I do get the correct elevations, how to I set the toposurface so that 5000 ft real elevation is at my base level of 0' 0"?
Thanks for any help.
Post edited on 2006-07-07 13:54:30
Ruth Rau Main Street Architecture, P.C. |
here is some info from the Revit OpEd blog that may be of help
http://revitoped.blogspot.com/2006/06/true-elevation-and-position.html
HTH
Topo elevation reports different value than actual location on z-axis in model |
Wed, Sep 26, 2018 at 11:47:41 AM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Deleted Topo Surface |
Fri, Apr 2, 2010 at 3:54:58 PM
CREATING A TOPO FROM A CIVIL CAD FILE |
Fri, Sep 29, 2017 at 3:22:33 PM
Topo Surface from autocad into revit |
Tue, Oct 13, 2009 at 10:37:25 PM
Members: | 2104250 | Objects: | 23178 | Forum Posts: | 152299 | Job Listings: | 3 |
