98 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to print sheets bigger than A0 as .dwf?
Thu, Jul 6, 2006 at 5:27:06 AM | How to print sheets bigger than A0 as .dwf?
mmetin
mmetin Avatar
while exporting to 2d dwf i can't choose find custom size...have an idae?
Fri, Jul 7, 2006 at 6:48:16 AM | RE: How to print sheets bigger than A0 as .dwf?
bobg
1. Why would you need to print bigger than A0 which is already the largest size? 2. To create bigger plot sheets you need to add them to the printer/plotter itself. Select your printer from the control panel/printers and go into the properties box where your sheet sizes are set up. This is where you add additional sizes. If this is a network printer/plotter then your IT staff will need to do it. It is a long process to describe here. 3. The size of your output is limited to the size of the device you are printing too. But in either case that is where you would do it. Bob
Revit views to DWF format to print
Fri, Mar 19, 2010 at 12:21:42 PM
DWF Printing
Fri, May 28, 2010 at 8:52:12 AM
DWF File Size
Fri, Oct 26, 2007 at 9:52:19 AM
Corrupt DWF from Sheets with dependent views
Wed, Feb 4, 2009 at 5:35:48 PM
Publish to Dwf problem.
Sun, Apr 18, 2010 at 5:28:54 PM
Page generation time: 0.3774
