134 Users Online (133 Members):
Forums >> Revit Building >> Technical Support >> Fill Pattern Scale Problem
2 Posts No Rating |
Hey out there, I scanned through a lot of old discussions, but couldn't find anybody who had this problem:
I downloaded and imported some new .pat files - but the option to change the scale or units is greyed out. If I edit the .pat directly, it doesn't have the ;%Units= line or anything, just the name of the file, and then the code. Any sugestions?
Thanks - I'm a newbie, but trying to figure things out myself before resorting to forum posts
The only way I know of is when you first import the PAT file you can define the "Import Scale" at that instance only. If the scale is not to your liking, then re-import the PAT file at a different Import Scale.
I have attached a JPEG file to show you where I adjusted the Import Scale.
I am a newbie, so if there is a better way out there that someone knows about, please post it.
I hope this helps you.
2 Posts No Rating |
Thanks Mal,
but even that import scale option is greyed out for me - is there some setting that I need to change to enable the import scale or something?
It shouldn't.
Do you have Revit 9?
Are you trying to change the scale after the PAT file has been imported?
Did you look at the JPEG file I attached?
How are you accessing the "New Pattern" dialog box?
Look into these questions. If this does not help, then you may want to E-mail me.
Good luck.
I AM HAVING THE SAME PROBLEM. THE SCALE OPTIONS ARE GRAYED OUT.
After you choose the pattern to load, the scale will no longer be greyed out and you can change it.
Scaling fill pattern |
Thu, Nov 17, 2011 at 4:01:24 PM
Material Fill Pattern Scale |
Mon, Nov 16, 2009 at 12:53:40 PM
Fill pattern not showing up in print |
Tue, May 1, 2012 at 11:20:14 AM
MEDIUM SCALE FILL COLOR AND PATTERN |
Tue, Sep 11, 2012 at 7:06:12 AM
Wed, Nov 12, 2008 at 7:30:12 PM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
