Forums >> Revit Building >> Technical Support >> Floor and Ceiling Levels
8 Posts No Rating |
When I create sections in plan view my floor and ceiling levels which are visible on the elevation view do not show up in the sections,
can somebody point me in the right direction please.
Check your visibility settings: VG
8 Posts No Rating |
had allready checked visibility settings everything is set to be visible but still no luck,
P.S thanks for reply
39 Posts No Rating |
Umm yea its weird ay. The only thing i can think of is its not a big enough section to include the levels. Like, the far clip may be cutting enough of a certain area, so it doesnt show the levels. All i can suggest is extending the crop and clip boundaries of the section or try drawing a few bigger/longer ones (not in the same place) and see what happens...
Hope that helps :D
8 Posts No Rating |
found solution, i did move the level marks at some stage in the project in elevation view,by moving them back to where thay roughly were thay beacame visible again.
thanks for your help anyway.
Not sure if this is the same resolution that you noted.
I've adjusted the cropping lines in elevation and section views until they cross the level lines. The level lines become visible when the two intersect on the screen. You can then adjust your level lines by grabbing the endpoint if you want to make your cropping window back to it original size.
8 Posts No Rating |
you are spot on icon i did have to adjust cropping lines
thanks for the post.
happy to help
Cannot see my floor levels |
Tue, Mar 10, 2015 at 12:42:27 PM
First floor slab or ground floor ceiling? |
Fri, Aug 30, 2013 at 7:41:04 AM
Tagging Floor levels |
Sat, Apr 25, 2009 at 2:08:54 AM
Floor levels slightly offset |
Mon, Nov 5, 2012 at 10:23:47 AM
FLOOR / CEILING PROB WITH HOSTING LIGHT FITTINGS |
Thu, Dec 15, 2005 at 10:30:39 PM
Members: | 2115722 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
