68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Separating walls
Mon, Jul 3, 2006 at 12:44:53 AM | Separating walls
Steiner
Good morning to you all! I've encountered a small problem regarding walls. It seems that whenever I take a single long wall, and split it, let's say, into 2 smaller walls, and then I try moving one of the walls and Revit still thinks it's 1 long wall... So, my question is, how can I make the walls split completely? So I'd be able to treat each one as a separate wall?
Mon, Jul 3, 2006 at 1:05:49 AM | RE: Separating walls
puzzle
4 Stars: 10 Votes
When you move (the command not dragging) the wall tick disjoin on the top command line. Or simply pull the wall slightly away from the other.
Macca
Sunshine Coast
QLD Australia
Mon, Jul 3, 2006 at 1:40:41 AM | RE: Separating walls
Steiner
Thanks for the reply puzzle, but those solutions don't work for me... I tried the move command from the toolbar, and the walls still act the same. Nothing disjoins itself... Perhaps I misunderstood you... Would you mind being a little more specific? Smile
Mon, Jul 3, 2006 at 5:22:58 AM | RE: Separating walls
puzzle
4 Stars: 10 Votes
Have post a screen shot. Not sure if this is what you had in mind. Select the wall you want to move, select move command then tick disjoin. Should be able to change height of the individual walls without upsetting the others. Hope this helps.
Macca
Sunshine Coast
QLD Australia
Mon, Jul 3, 2006 at 8:18:22 AM | RE: Separating walls
Steiner
Edit: Never mind I found the Disjoin thingie thank you so much puzzle!! Smile Post edited on 2006-07-03 08:28:46
separating walls
Tue, Apr 26, 2005 at 7:04:01 PM
Joining Cavity wall with separating wall
Mon, Jul 14, 2014 at 9:12:32 PM
DWG export, separating materials..?
Thu, Apr 18, 2013 at 5:02:36 PM
Separating wall/ external wall junction
Wed, Nov 9, 2005 at 9:44:27 AM
Finish Flooring as part of Structural Floor assembly
Fri, Dec 26, 2008 at 8:42:15 PM
Page generation time: 0.5529
