41 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Casework Problem
25 Posts No Rating |
When I place a bathroom vanity cabinet on my first floor plan it also appears on my basement plan. Nothing else, tubs, sinks, etc., exhibit this behavior.
Any ideas?
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
i would check the cut plane on your beasement plan as well as the vanity properties, height, where it's placed... as well as the family itself for the above.
I thought about the cut plane but it is only casework that is showing up. The heiights on the casework instance is correct and it is placed on the correct level.
...and you don't have level 1 as an underlay?
where did you get the family? can you post it?
Figured it out. I had received the file from someone else and they had changed the view range top to be the First Floor.
Phantom Casework |
Tue, Aug 28, 2012 at 12:25:48 PM
Casework below countertop not visible. |
Wed, Jan 27, 2010 at 2:16:58 PM
Casework below in-place component won't show - R09 |
Fri, Dec 4, 2009 at 11:50:12 AM
shower enclosure & casework visiblity |
Sun, Nov 5, 2006 at 12:53:09 PM
Capturing room number and name data for casework, furniture, etc. |
Tue, Sep 20, 2005 at 8:45:55 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
