64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall with repeating Vertical items.
Wed, Feb 12, 2025 at 6:27:39 PM | Wall with repeating Vertical items.
vinnygolfer
4.5 Stars: 4 Votes
I'm sorry if this is a topic that has already been discussed here.
I'm working in Revit 2024 and trying to recreate an existing building from dwg. the building has 3" fabricated metal panels, so it needs to have a vertical line that shows up every 1' 10". I have not been able to figure out how to create a wall with this feature. I ended up using a curtain wall system, and making it have no horizontal mullions for inside. but then when I need to place a door, I have to prake the wall and make a new one that has 1 horizontal line, and editing it so that I can place a door. I have attached a sample of this. it's a big project and it's going to be a major pain. and this is typical of most of the buildings that this company works on. I need to find a better mousetrap for this.
any help with this would be much appreciated.
Thank you
Try to learn at least one new thing every day
Thu, Feb 13, 2025 at 9:26:17 PM | Wall with repeating Vertical items.
3.5 Stars: 397 Votes
I used a 3D material for this.
How do i make a foam wall with repeating vertical reveal
Sat, Nov 18, 2017 at 10:50:48 PM
Repeating Detail Items
Sun, Aug 30, 2009 at 9:22:55 AM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
Repeating Pattern
Wed, Jul 5, 2006 at 1:58:33 AM
Non-Continuous, Repeating Wall Sweep
Wed, Jun 29, 2011 at 10:49:55 AM
Page generation time: 0.7933
