51 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Annotation family puzzle
Tue, Feb 4, 2025 at 4:10:09 PM | Annotation family puzzle
kotik95
Dear forum members, I need your help to solve two challenges in order to pass my entrance test.
1. Create annotation family (tag example on the first image):
- A text should have three options for alignment: left-aligned, right-aligned, centered.
- A text also has multiple rows, the number of rows is not limited, the first row always lies on a line.
And here is one confusing moment. Experienced users may know that width of label can not follow line length and each individual case demands new family type. Is there a way to get the job done?
2. The second task:
The drawing must be divided into equal squares. The number of rows and columns depends on sheet size and follows corresponding parameter. Each row and column must have a label (see the snippet on the second image). For example:
- A0: numbers from 1 to 11, letters from A to H
- A1: numbers from 1 to 8, letters from A to F
 It would be great if you have any ideas how to implement this in title block family! Thank you in advance!
Wed, Apr 2, 2025 at 6:37:45 PM | Annotation family puzzle
3.5 Stars: 400 Votes
Have you ever created a Revit family?  If not, then you need to either take a class or find an instruction manual.
If you are creating a family and have run into a snag, then a specific question would be welcomed here along with a display of what you have done.
Don't expect us to pass your qualifications test for you.
Family annotation text in 2D
Sun, Jan 30, 2011 at 9:06:29 AM
Rotating Annotation Family
Wed, Nov 5, 2008 at 3:25:53 AM
Issue with annotation nested with generic model family
Wed, May 25, 2016 at 9:46:10 AM
FAMILY ANNOTATION
Thu, Jul 13, 2017 at 12:06:43 PM
Checkbox on annotation family
Fri, Oct 31, 2014 at 1:11:52 PM
Page generation time: 13.2007
