70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> CREATING DETAILS USING DETAIL COMPONENT
Mon, Jun 26, 2006 at 1:36:34 PM | CREATING DETAILS USING DETAIL COMPONENT
cirees0012
1 Stars: 1 Votes
I AM CREATING A DETAIL USING DETAIL COMPONENT. PART OF THE DETAIL IS EXISTING AND THE REST IS NEW WORK. THE PROBLEM IS I LIKE TO SHOW THE EXISTING COMPONENT LIGHTER THAN THE NEW BUT CAN'T FIGURE OUT AWAY TO ACCOMPLISH THIS TASK. ANY SUGGESTION THANKS IN ADVANCE
Mon, Jun 26, 2006 at 4:00:04 PM | RE: CREATING DETAILS USING DETAIL COMPONENT
ICON
5 Stars: 3 Votes
You might get the result you're looking for by going to the "tools" drop down menu select "linework" select "thin lines" in the type drop down box in the header bar then highlight the lines you wish to change. There's a way to add lines to that selection set, but I haven't done a lot yet with creating linetypes.
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:46 AM
Stone Detail Component???
Fri, May 31, 2013 at 3:56:20 PM
snap to filled regions in detail components
Tue, Jun 7, 2005 at 2:14:20 PM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:26 PM
Repeating Detail Component for Metal Lath
Tue, Apr 1, 2008 at 12:59:07 PM
Page generation time: 0.5283
