44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Irregular walls
Wed, Sep 15, 2004 at 7:52:26 PM | Irregular walls
Osir
I am looking to create a series of walls that : 1) decrease in width from 6" at top to 24" at bottom 2) decrease in length from 20' long at bottom to 15' at top 3) decrease in height from 9' at one end to 8' at the other end Are there tutorials to help me figure out how to do this?
Wed, Sep 15, 2004 at 8:20:52 PM | RE: Irregular walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I'm not sure of any, but they will need to be created as in-place wall families. If you read through one of the revit in-place family tutorials in might give you some idea. But basically I would create a large mass wall and then use voids to cut the unwanted sections.
Wed, Sep 22, 2004 at 1:20:43 PM | RE: Irregular walls
Osir
In addition, I needed to batter (slant) one side of an eliptical (in plan) wall. I was able to do this as an In-Place family, but found that 'normal' walls would not trim to (or intersect) this wall. Any better way to do it so that they will trim?
Wed, Sep 22, 2004 at 6:41:34 PM | RE: Irregular walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You would need to edit the profile of the intersection walls manually to trim to the angled wall.
Wed, Sep 22, 2004 at 7:16:16 PM | RE: Irregular walls
Osir
Ohhhh. That makes sense... and makes for some work! But hey, its a solution. Thanks!
Irregular (on plan) shaped walls
Thu, Nov 23, 2006 at 3:28:48 AM
Irregular Ceiling
Mon, Aug 4, 2008 at 1:45:53 AM
irregular patterned stucco wall
Tue, Jan 27, 2009 at 9:03:42 AM
Is there a way to subtract roof geometry from wall - Take a look at attachment
Thu, Feb 9, 2012 at 2:59:44 AM
how to make an irregular slope surface
Fri, Apr 1, 2011 at 10:12:28 PM
Page generation time: 0.6823
