83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> North Arrow
Fri, Jun 23, 2006 at 8:17:51 AM | North Arrow
arkitektmsh
3 Stars: 1 Votes
Is there some way to create a north arrow family that can be placed in a title block and given parameters for visibilityand rotation? Any help would be appriciated. On a side note, has anyone though about creating a north arrow that automatically orients itself to true north after placing in the project?
Sun, Jun 25, 2006 at 6:10:21 PM | RE: North Arrow
eldados
eldados Avatar
4.5 Stars: 8 Votes
of course you can! Smile tried to upload but my server doesn't like it... email me if you get stuck
Integrator
KarelCAD
Wed, Jul 5, 2006 at 8:55:04 AM | RE: North Arrow
arkitektmsh
3 Stars: 1 Votes
Didn't see an attached file. Try it again or email it to me. Thanks for your response. I guess you won't get this for a while because its tomorrow already where you are. Lot of you Aussies on these forums. Good to see.
Wed, Jul 5, 2006 at 7:42:07 PM | RE: North Arrow
eldados
eldados Avatar
4.5 Stars: 8 Votes
just send me an email Smile
Integrator
KarelCAD
Tue, Jan 16, 2007 at 1:05:50 PM | North Arrow
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
The emailing thing works well, until someone else has the same question Smile
I have our office's standard title bar with a north arrow that turns on and off. It was our understanding (from a Revit implementation specialist) that these would be parametric to Revit's "True North". I'm now looking at it more closely and see no parametriciousness (my new word) to it. I can rotate my True North all over the place, but the north arrow sits...lifeless...mocking my Revit inexperience.
Tue, Jan 16, 2007 at 2:49:16 PM | North Arrow
jterrell
3 Stars: 5 Votes
Here's the one we use. The north arrow rotation is a type parameter in the family.
Edited on: Tue, Jan 16, 2007 at 2:50:20 PM
Tue, Jan 16, 2007 at 3:22:57 PM | North Arrow
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
Your title is set up similar to ours...but what I am wanting is a north arrow that parametrically (read automatically) adjusts per project orientation. Any ideas?
Tue, Jan 16, 2007 at 5:27:27 PM | North Arrow
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Its quite easy to have a north arrow have a type parameter in your titleblock that is set once for a project for its orientation.  This is exactly what we do.
However it is not currently possible to link this with the actual project orientation, so you could rotate your project and have the arrow adjust.  This is still a manual process.  But using the previous method at least it only needs to be done once.
Regards,
Chris.
Tue, Jan 16, 2007 at 9:24:45 PM | North Arrow
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
Thanks for letting me know. I can stop the pointless exercise of figuring it out. Now, on to my next Quixotic Revitventure!
Rotatable North Arrow
Mon, Dec 29, 2008 at 6:02:49 PM
North Arrow
Fri, May 6, 2016 at 7:09:48 AM
Trying to create a Plan Title with a rotating north arrow
Wed, Oct 13, 2010 at 9:51:09 AM
North Arrow for v.2011
Fri, Dec 9, 2011 at 7:05:58 AM
ROTATABLE NORTH ARROW BUT NOT TEXT
Sun, Jun 3, 2018 at 8:30:20 AM
Page generation time: 0.2842
