80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> slopped pad
Thu, Jun 22, 2006 at 8:12:50 PM | slopped pad
gsaia
I have a 250' long building wiht a difference of 3' on its grade. I would like to place something like a slopped pad. Is there a way to do this?
Fri, Jun 23, 2006 at 2:53:57 AM | RE: slopped pad
puzzle
4 Stars: 10 Votes
I'm not 100% sure but when you make the pad is there a slope arrow just above the pad properties.
Macca
Sunshine Coast
QLD Australia
Fri, Jun 23, 2006 at 7:23:17 AM | RE: slopped pad
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this tutorial loacted in the Revitcity Tutorials http://www.revitcity.com/tutorials/complex_slabs/ HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Jun 23, 2006 at 9:42:33 AM | RE: sloped pad
gsaia
Thanks for the replies so far. Coreed, The tutorial is very good and is a good way to handle an irregular floor. However, I need the ground below to "attach" to the bottom of my slab and cut through a toposurface similarly to what a pad does. Puzzle, There is no slope arrow. I tried to set a work plane to match a sloped slab I created, but it seems that Revit cannot use (or I do not realize how to, in this case) the inclined plane of the slab as a work plane while in the pad command. (I can set the work plane to the face of the slab when I'm not in the pad sketch mode) A sloped pad is something so much needed because, in most cases, slabs on grade are sloped!!
Topo slopped pad (parking lot/road)
Mon, Aug 24, 2009 at 8:26:24 AM
SLOPPED FLOOR
Wed, Jul 23, 2008 at 12:06:37 PM
SLOPPED BEAMS
Thu, Jan 16, 2014 at 1:00:33 PM
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:09 PM
Roof condition
Thu, Jan 14, 2010 at 12:37:18 PM
Page generation time: 0.2701
