43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Wall tags don't show type mark
3 Posts No Rating |
Hi,
I set a mark number in the wall type and when I add a wall type the tag is blank. Any ideas ??
Thanks,
Ray
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Ray,
The default wall tags read from the Mark parameter of each wall instance. If you want a tag to read the Mark parameter from the wall type, you need to make another wall tag symbol that uses the 'Type Mark' label instead of the 'Mark' label.
HTH, GL
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
Window tags & showing window #(Mark) on plan |
Thu, Nov 3, 2005 at 9:46:11 AM
type mark tags and height/width reference |
Mon, Apr 13, 2015 at 10:04:42 AM
Warning: Elements have duplicate 'Type Mark' Values - Casework |
Tue, Jul 19, 2011 at 11:04:51 AM
Hello Newbie here, brick on brick on cmu wall type doesn't show up |
Thu, Jan 27, 2011 at 1:06:15 PM
custom tags |
Fri, May 11, 2012 at 1:32:35 PM
11
Members: | 2026045 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
