Forums >> Revit Building >> Technical Support >> patttern downloads
3 Posts No Rating |
I recently had a problem downloading fill patterns. After much trial and error, and consulting with another Revit user, I was able to overcome the problem, but it seems like an awkward way to download patterns. As an example when I download a brick pattern from RevitCity and save it to my library it is saved as “2x2_Brick_Pattern_87_pat.htm” file. I then have to go back into my library and rename the file “2x2_Brick_Pattern_87.pat” before I can import the pattern into a project. Is there an easier way to download, so it can be done in one step?
your patterns should be downloading as .pat files directly and not as .htm files
what web browser are you using
3 Posts No Rating |
I am using Microsoft Internet Explorer.
Hi there just thought I'd share this familiy I did a long time ago. Just bring it into your project and it will load alot of the hatch patterns that you can find out there.
Flooding of files in downloads |
Tue, Sep 20, 2022 at 5:04:20 PM
Downloads |
Thu, Jun 14, 2018 at 8:04:41 AM
Downloads |
Tue, Oct 15, 2019 at 10:03:34 AM
Where is the Line Patttern info stored. |
Mon, Dec 1, 2008 at 9:00:57 AM
Not able to view pictures in Downloads |
Wed, Apr 13, 2011 at 7:47:06 PM
Members: | 2119216 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
