39 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> Rollback option
14 Posts No Rating |
Can anyone help me with the rollback option and where it is located in the commands? I did it last week and now it has completely escaped my memory on how to set a drawing back two hours when one does not have the undo command available. Thanks.
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
The only thing I can think of is to use the autosave file. Everytime you save (unless you changed the settings) it will put a file called 'Projectname.00#.rvt' in your project folder. Use one of those to get close enough.
Other than that I'm not familiar with any rollback options. Sorry.
Good luck!
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
On a worksetted file:
File-->Backups..-->Pick backup directory then pick the file you want to roll back to and hit rollback.
Rollback |
Thu, May 22, 2008 at 5:48:12 PM
Cannot make design option primary |
Thu, Jan 6, 2011 at 2:08:04 PM
Design Option Issue - walls in 1 design option cutting thru a 2nd option |
Thu, Oct 21, 2010 at 11:55:04 AM
Restoring from a backup file when filesharing |
Thu, Jun 3, 2010 at 11:12:22 AM
Mysterious duplicate option sets |
Wed, May 2, 2007 at 10:05:19 AM
Members: | 2017275 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
