83 Users Online (82 Members):
Forums >> Revit Building >> Technical Support >> download question
2 Posts No Rating |
I'm kind of a new guy. Started Revit a about 6 or so months ago.
Anyway. I was trying to download a stone fill from this site...I did the right click and "save target as" because it came up as gibberish...so I went back to revit and tried to load the component, but when I went to the folder it was in, it wasn't there. Am I missing a step or something?
Can somebody help a guy?
thanks.
Hi
Try using the download button on the top right hand corner of the title block of each fill pattern in the fill pattern tab! When you press this a page will come up with the following message: "Thank you for downloading from Revitcity.com"
Just read the the rest of the text on the page as well and follow any instructions giving! For example:"If your download does not begin in 15 seconds, 'Click Here' to download". Whe you press on the 'Click Here' tab a File Download dialogue box comes up promting me to Open or Save the file! Choose save and save in location required! This should save a *.pat file which is you pattern code!
If you save target as, I do believe you would get a *.htm file. Make sure you download the file in *.pat format!
Hope this helps
Regards,
Nic
Can't download anything anymore! |
Mon, Jun 20, 2016 at 3:11:42 AM
cannot download drawings from revitcity |
Sun, Jun 25, 2017 at 2:02:49 AM
Download Revit 2010 Now!! |
Mon, Oct 12, 2009 at 10:42:37 AM
download doesn;t work |
Fri, Jun 1, 2018 at 3:50:43 PM
Dont know how to download families |
Wed, Jan 31, 2018 at 11:50:15 AM
12
Members: | 2017008 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
