77 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Design Options and Room Separation Lines
Fri, Aug 16, 2024 at 6:56:51 PM | Design Options and Room Separation Lines
pgrimmi
I am working on a couple of design options for a office renovation. I created a group using 3d panels for cubicles and included room separation lines for cubicle wall (see below). The cubicle group is in both design options The intention is to create a room schedule to include the cubicles.
The challenge is that the room separation lines from the other design option is showing up in my view and when I try to place rooms in the cubicles, they overlap (see below)
So I was wondering if there is a way to turn off the room separation lines for the other design option? I looked into using a filter, but room separation lines aren't available in the filter elements selection. Maybe the trick is to remove the separation lines from the cubicle groups and use them in the design options instead? Appreciate any help!
Design Options and room numbers
Fri, Dec 3, 2010 at 2:17:22 PM
room bounding not recognizing room separation line [ 1 2 ]
Thu, Aug 18, 2016 at 10:02:15 AM
16
Room Separation Lines won't display [ 1 2 ]
Mon, Feb 19, 2018 at 2:00:12 PM
15
Room Separation
Sat, Nov 3, 2007 at 3:19:42 PM
Room Separation Lines showing up from lower levels as halftone
Wed, Dec 22, 2010 at 12:17:21 PM
Page generation time: 2.2436
