31 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Elevation Tags
Tue, Jun 20, 2006 at 6:50:20 PM | Elevation Tags
arkitektmsh
3 Stars: 1 Votes
We ahve had numerous complaits as to the appearance of the elevation tags. They are so far off of our standards that we need to find a way to modify their appearance. Can anyone tell me a good way to change the appearance of these tags without sacrificing the "intellegence" of the tags? Any help would be nice. P.S. I have read the revitrants blog that uses modifies section cuts as a workaround. This is a good workaround but the symbol is still far different from what is needed.
Tue, Jun 20, 2006 at 7:12:08 PM | RE: Elevation Tags
dduarte
dduarte Avatar
3 Stars: 2 Votes
If you use the section cuts workaround you should be able to redesign the section head. Look for it in the project browser under Families... Annotation Symbols.
Tue, Jun 20, 2006 at 7:25:18 PM | RE: Elevation Tags
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
By making the elevation markers as section markers in disguise you should be able to achieve what you're after, as section markers use external families and are pretty much fully customisable. Could you post a screenshot of what you are trying to achieve? As the section marker workaround should work.
Tue, Jun 20, 2006 at 8:06:38 PM | RE: Elevation Tags
coreed
coreed Avatar
4 Stars: 16 Votes
sorry Post edited on 2006-06-20 20:08:39
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jun 21, 2006 at 5:04:25 PM | RE: Elevation Tags
arkitektmsh
3 Stars: 1 Votes
Thanks for the responses. After searching around for a while i have found that all of you guys are correct. Now its up to the bosses here to let me run with this.
Wed, Jun 21, 2006 at 9:13:57 PM | RE: Elevation Tags
jreviteer
The idea of using section symbol for elevation symbol to meet standard in your construction document is good. I recently stopped using that method because these fake elevation symbols are not working when I exported my drawings to DWF format. The beauty of elevation symbols in DWF format is that when you click on them, they will take you to the elevation drawing sheet. Fake tags do not do that. Our firm works closely with Autodesk Revit representative to make a big push on this problem.
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Elevation Tags
Tue, Oct 23, 2007 at 4:30:06 PM
Custom Elevation Tags
Thu, Mar 17, 2011 at 5:09:02 AM
2011 interior elevation tags
Thu, Dec 23, 2010 at 11:44:57 AM
Multiple Elevation Tags
Mon, May 24, 2010 at 3:20:16 PM
Page generation time: 2.8669
