Forums >> Revit Building >> Technical Support >> WALL SHEATHING AND EXTERIOR FINISH
Mon, Jun 19, 2006 at 9:27:44 AM | WALL SHEATHING AND EXTERIOR FINISH
BRIANDHADLEY
1 Stars: 1 Votes
MY WALL IS SITTING ON THE FLOOR JOISTS WHICH ARE SITTING ON THE FOUNDATION WALL (PLATFORM FRAMING). HOW CAN I EXTEND THE SHEATHING AND EXTERIOR FINISH DOWN TO THE LEVEL OF THE TOP OF FOUNDATION WALL?
Mon, Jun 19, 2006 at 9:55:14 AM | RE: WALL SHEATHING AND EXTERIOR FINISH
coreed
coreed Avatar
4 Stars: 16 Votes
i don't have time at the moment to list all the steps, but you will find your answer in this Autodesk training video http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=3623410&linkID=3770380 HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jun 19, 2006 at 10:05:55 AM | RE: WALL SHEATHING AND EXTERIOR FINISH
stevelj
Select wall go to properties edit/new edit structure - bottom of properties will expand w/a bunch of selections go to preview view: section select modify zoom into the bottom of your wall select the layer you want to change its length unlock it you should see at least two blue triangles OK,OK, OK go back to building wall section where condition occurs select wall to modify you should see the blue triangles just drag it down to top of wall that's it
Exterior finish on wall not exterior enough... ?
Fri, Jun 3, 2011 at 8:44:28 PM
Wall Finish
Wed, Aug 9, 2006 at 6:02:51 PM
exterior finish error
Tue, Jun 16, 2009 at 1:22:12 PM
exterior finsh below zero
Sun, Apr 11, 2010 at 10:13:36 AM
location line of wood sheathing
Fri, May 27, 2016 at 8:43:13 AM
Page generation time: 9.2476
