Forums >> Revit Building >> Technical Support >> Painted surface
Is it possible to find out what material has been used to paint an object?
Macca Sunshine Coast QLD Australia |
Go to "settings" then "options" Go to the "General" tab. Make sure you have enabled "tooltips assistance" to anything except "None" <P> very important<P>Then go to paint bucket tool or split face tool, then hover over the resgion you have split, in a reasonable view. (if you drew a facade elevation with painted surfaces, go there to inquire)) The area you split highlights, it will bring up a tooltip listing what the surface is, and if the paint command was used, it will indicate the original surface material, as well as the painted surface material.<P>I wanted to post you a screenshot, but I can't get the screenshot to include the pop-up tooltip! sorry!
----------------------------------- CRI |
Align painted surface |
Fri, Jul 22, 2016 at 1:28:23 PM
painted split face doesn't show in dependent view |
Mon, Nov 1, 2010 at 12:32:14 PM
Floor pattern showing through objects |
Tue, Apr 1, 2014 at 7:52:44 AM
How to take quantities from painted surfaces? |
Tue, Oct 10, 2017 at 1:00:44 AM
painted cmu wall.. |
Thu, Nov 14, 2013 at 11:16:50 AM
Members: | 2115698 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
