70 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Solution 2D DWG to REVIT Pls
Sat, Jun 17, 2006 at 3:16:00 AM | Solution 2D DWG to REVIT Pls
kamo
kamo Avatar
I need HELP I am using 2D drawing in Autocad(R) for several years ( also extrude 3D) is there a best way to translate my 2D to REVIT now i can only see that importing 2D dwg files from ACAD can only be used as a trace line for revit IS THAT SO or am i still missing some Good procedures I wanted my 2D dwg to be translated easily to revit THANKS for HELP ~~ ANY
Sat, Jun 17, 2006 at 6:03:01 AM | RE: Solution 2D DWG to REVIT Pls
coreed
coreed Avatar
4 Stars: 16 Votes
you are correct you cannot directly translate your 2d autocad files into revit files HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Jun 17, 2006 at 7:44:20 AM | RE: Solution 2D DWG to REVIT Pls
kamo
kamo Avatar
MAny thanks Coreed for immediate response. means after i imported my 2d walls unto REVIT i will have to redraw all parametrically then i will have to delete my acad layers after all if i am doing my 3D project many thanks again
Sat, Jun 17, 2006 at 12:43:30 PM | RE: Solution 2D DWG to REVIT Pls
TomDorner
4.5 Stars: 25 Votes
I would "link" the CAD file into Revit rather than import it. There is a "link" box that you can check and the link then acts like an xref. When you are done using the ACAD file then go to "manage links" and delete it or simply select the linked image and hit the delete button. Linking the file in will ensure that no unwanted remnants of a CAD file remain in the Revit file. Tom
Sat, Jun 17, 2006 at 1:52:54 PM | RE: Solution 2D DWG to REVIT Pls
kamo
kamo Avatar
tomdinmn thanks 'buddy twas a ton full of very nice tip will do thanks ! // just wish i can extrude the 2d wall to revit Sad anyway thanks
Sun, Jun 18, 2006 at 5:59:25 AM | RE: Solution 2D DWG to REVIT Pls
kamo
kamo Avatar
heres my 1st try . NEED COMMENTS THANKS
Sun, Jun 18, 2006 at 6:04:14 AM | RE: Solution 2D DWG to REVIT Pls
kamo
kamo Avatar
cont ...(cannot attach 2 files a time) to construct topo/pads from dwg file (linked). Post edited on 2006-06-18 09:45:54
components-sizes small..pls help
Thu, Jun 15, 2006 at 4:39:50 AM
Dwg export: revit 2013 ignoring subcategories
Thu, Jul 25, 2013 at 8:12:44 AM
Revit 2015 - Importing complex 3D DWG
Thu, Apr 30, 2015 at 7:14:46 AM
Subregion export .DWG
Mon, Feb 20, 2012 at 3:42:38 AM
Problem during Installation in REVIT 2010... pls HELP (i'm new)
Tue, Jun 16, 2009 at 12:42:39 AM
Page generation time: 2.0220
