95 Users Online (94 Members):
Forums >> Revit Building >> Technical Support >> Section and Detail Tails
I tried searching for an answer to my problem thru the search function but couldn't find anything. Thus I come to you, the community, to receive some insight.
I'm looking to find out how to modify and upload section and detail tails into my project. I'm currently using the standard tail for details but it is too thick and looks like it could be another wall.
I've tried creating new tails by locating the standard tail and then saving it as a new file but after trying to load it into the project I can't seem to choose the new tail as an option.
How do I go about modifing the tail on a detail and then have it recognized in the project?
Thanks
You modify a tail by going to: "Settings" menu -> "View Tags" -> "Section tags..."
There you can choose different tails under the "Tail Tag" drop down menu. If you created a new tail tag by modifying a existing one a loaded it into the project, it should come up in the drop down list!
Hope this suggestion is of some help!
Revit 2009 : Section Tails: How to create custom Section Tails |
Thu, Jul 17, 2008 at 3:25:05 PM
Section Cut tails |
Wed, Mar 28, 2007 at 1:46:10 PM
Detail/Section Heads and Tails Not Connecting? |
Fri, May 7, 2010 at 8:02:49 AM
Section Cut heads and tails automatically toggle on when you adjust crop region |
Wed, Oct 10, 2007 at 11:45:19 AM
Adjustable Section Tails |
Wed, May 4, 2011 at 1:29:44 PM
Members: | 2030567 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
