64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> window sills
Fri, Jun 16, 2006 at 2:00:59 PM | window sills
marcomac
has anyone figured out a clever way to make window sills? I modified my window families by adding a sill-shaped sweep to the bottom of my window. this means that my opening cut has to start underneath the sill though. fine for elevations but theres a gaping hole behind the sill on interior shots. any better ideas?
Fri, Jun 16, 2006 at 3:07:42 PM | RE: window sills
dduarte
dduarte Avatar
3 Stars: 2 Votes
You could replace the Opening Cut in the window family with a void that cuts the wall. Revit won't let you cut a host wall with a void AND a opening cut.
Sun, Jun 18, 2006 at 1:20:44 PM | RE: window sills
marcomac
thanks for the help dduarte
Sun, Jun 18, 2006 at 5:16:17 PM | RE: window sills
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just a word of caution with doing this, some functionality will be lost for windows: For instance, when two parallel walls are less than 15mm apart and the join geometry tool has been used, revit will cut an opening to match if there is a window in one of the hosts. If the window uses a void this will not occur. HTH.
Stone Window Sills
Wed, Jul 16, 2008 at 9:44:33 AM
Window Sills in Revit Arch. 2008
Thu, Dec 27, 2007 at 9:12:44 AM
Creating Window Sills
Tue, Jul 3, 2012 at 1:26:39 PM
Window sills and head
Thu, Apr 7, 2005 at 9:11:03 PM
brick sills under windows
Sat, Feb 4, 2006 at 9:28:05 AM
Page generation time: 7.6466
