107 Users Online (106 Members):
Forums >> Revit Building >> Technical Support >> "Can't make stairs" error when creating a straight + helical stair
I need to create a staircase consisting of a straight ramp and a helical ramp.
I used the "staircase" command and created the straight ramp and with the flag on "automatic landing" I tried to create the helical ramp.The result is that, if I follow the path of the staircase, the warning "impossible to create staircase" appears, but if I widen with respect to the path, the staircase is created without problems (here are photos of the two cases:
How can I solve this? It seems that the problem lies in the landing
Thank you
(Sorry if the English is not perfect but I am writing from Italian and with Revit commands in Italian so the name of some may be slightly different, I hope you understand anyway)I'm using Revit 22
Edited on: Sat, Jan 14, 2023 at 10:02:40 AM
Error message creating stairs |
Tue, Jul 13, 2010 at 7:27:11 PM
revit can't make component stair |
Fri, Jan 8, 2016 at 1:16:21 PM
Ramp error "Stairs require no more than two boundaries....) |
Mon, Apr 25, 2016 at 9:02:19 AM
Error when inserting stair |
Fri, Feb 6, 2009 at 11:56:07 AM
Helical Ramp |
Wed, Mar 10, 2004 at 8:51:07 AM
Members: | 2030717 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
