50 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Graphic overrides by phase
Hello!
I'm trying to use graphic over rides by phase to differentiate new walls from existing walls. I'm trying to make the cut section of the existing wall dark gray and light gray for new walls. This is for presentation only and will revert back to a different visual scheme for CD's. My existing walls are showing up dark gray. Perfect. But the new walla are not turning to light gray?!? They stay white despite the override. I've assigned the correct phase to each wall in the properties dialog box. Any idea why phase override is not effecting the new walls? Thanks in advance!
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Are you using a filter for the existing walls? Do the same thing for the new walls using phase created --> new construction and then set the override for the cut pattern.
Phase Graphic Overrides |
Wed, Jul 10, 2019 at 4:01:45 PM
Dual Phase Graphic Override? |
Tue, Apr 28, 2009 at 9:23:26 AM
conflicting graphic overrides... |
Fri, Oct 12, 2012 at 10:44:04 AM
Phase Graphic Overrides Not Working!! (very frustrated) |
Fri, Aug 7, 2009 at 9:41:12 AM
Graphic overrides (phasing) for 3D views |
Wed, Apr 30, 2014 at 2:25:42 PM
Members: | 2017036 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
