86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rotating Views on a Sheet
Wed, Jun 14, 2006 at 8:40:19 PM | Rotating Views on a Sheet
chewingzafat
How do I rotate a floor plan on a Sheet so make it line up with the matching elevation?
Wed, Jun 14, 2006 at 10:35:51 PM | RE: Rotating Views on a Sheet
jreviteer
There are two ways to approach this problem: 1. In the sheet view, you can right click on the view and scroll down to select "Activate View" option. Make sure that the crop region is on. If is is not on, you can right click and go to "View Properties" and check on the box for crop region. If the crop region is on, you need to click on the crop region box to select the view. Then, you go to "Rotate" and rotate the view. After everything is done, you can turn of the crop region. Now, you can right click to select "Deselect View " option to go back to the sheet. 2. In the working plan view, you can click on the crop region box to select the region boundaries. Then, you go to "Rotate" to rotate that particular view. You can perform this step after or before you put your plan view on the title block.
Thu, Jun 15, 2006 at 10:01:08 PM | RE: Rotating Views on a Sheet
chewingzafat
Ok. THanks very much. What if I have a piece of custom furniture in a plan for an apt that I want to hone in on to show more details in plan & elevation? How do I crop region for the plan?
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating Views on a Sheet -180
Tue, Nov 5, 2013 at 9:44:26 AM
Rotating Views on Sheet
Tue, Jan 19, 2010 at 12:30:55 PM
Rotating Project North and Sheet view North not rotating
Mon, Oct 12, 2009 at 9:34:25 AM
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Page generation time: 1.0686
