49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Using a C-Channel as a column
Wed, Jun 14, 2006 at 10:58:37 AM | Using a C-Channel as a column
GeneralissimoDigital
I'm very new to the program so... Is there a way to use a C-Channel as a column? I have a condition that is using a C12x30 vertically. Do I need to create one from scratch (or from an existing W-shape column)? i'd be at a loss to pull that off. Thanks
Wed, Jun 14, 2006 at 4:45:09 PM | RE: Using a C-Channel as a column
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Yes you can do that, you just need to have a column family that is made for that. If you can't find one then you need to create it.
Hiroshi Jacobs
Beam Joins Not Working Correctly
Wed, Jun 27, 2012 at 5:42:47 PM
Created channel column shows off its structural axis (physical appart blue line)
Thu, Jun 27, 2013 at 5:46:12 AM
C-Channel Profile sweep issues?
Fri, Apr 29, 2011 at 11:47:24 AM
Tapered C Channel
Sat, Feb 17, 2018 at 4:11:57 PM
C-channel Stair Stringers
Wed, Apr 20, 2016 at 10:22:31 AM
Page generation time: 0.3431
