108 Users Online (107 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Printing
Wed, Jun 14, 2006 at 8:12:54 AM | Printing
JHanby
3.5 Stars: 3 Votes
How come when you select a sheet to print you don't get the preview? Is there a way to preview the selected sheet before it goes to the printer?
Jill
Wed, Jun 14, 2006 at 9:53:36 AM | RE: Printing
ATisue
as far as I know, you cannot preview the page when you select a sheet to be printed. However, if you make sure that the paper placement option of "center" checked, as well as the "zoom 100%", in the Page Setup dialog box (as well as of course the correct printer/paper size/orientation), you won't need to preview as your print will come out correctly.
Wed, Jun 14, 2006 at 12:11:17 PM | RE: Printing
JHanby
3.5 Stars: 3 Votes
Thanks for the response. I had tried that and the print came out off center. I need a good tutorial on just printing alone. Getting the hang of everything else so far.
Jill
Wed, Jun 14, 2006 at 3:01:00 PM | RE: Printing
bolandereric
I have noticed that some times when I push the print button sometimes it will not let me look at the preveiw. It will not let you preview if you are selecting multiple sheets to print at the same time. Cancel the print job open the page that you want to print click on the screen by the object you are trying to print and then hit the print button again. Try it, it has worked for me.
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:02 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:16 AM
17
Printing Query
Wed, May 23, 2012 at 7:54:09 AM
Printing
Thu, Jun 14, 2018 at 12:59:05 AM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:40 PM
Page generation time: 0.2518
