91 Users Online (90 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> sloping structural beam system - having difficulty in drawing
Tue, Dec 28, 2021 at 1:10:42 PM | sloping structural beam system - having difficulty in drawing
elizabethpetermathew
Hello,
I am trying to draw a sloped structural beam system. I have drawn it in the recent past, maybe 2 months ago. Now in the user interface I am not getting the right options. I cannot see the automatic beam system option. See attached image 2. That is the window that I am getting now when I go to the structural beam system drawing option. The image 1 shows the correct user interface but that is not showing up. Not sure what I am doing wrong, but this is getting vvery difficult. I tried autodesk help and it show the correct window and options. Any help is much appreciated. Thank you.
Wed, Dec 29, 2021 at 10:03:45 AM | sloping structural beam system - having difficulty in drawing
Does this help or has it changed since this was made?
https://www.youtube.com/watch?v=BSDvtWDrRG4
Wed, Dec 29, 2021 at 2:35:26 PM | sloping structural beam system - having difficulty in drawing
The youtube video does show the right screen with the correct options, but when I go to the structural beam sytem option it does not show me the right window. So I had to draw one sloping beam in plan and array it. I could not drawn it using the structural beam system.
Thank you.
Thu, Dec 30, 2021 at 10:33:03 AM | sloping structural beam system - having difficulty in drawing
If you listen to the video, he tells you right at the beginning "You can't use the beam system, you have to do them manually" ... drawing a flat beam, then dropping one end.
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:44 PM
structural beam system visibility
Fri, Jun 27, 2008 at 12:24:52 PM
structural beam system irregularity
Fri, Dec 19, 2008 at 3:03:11 PM
Structural beam system visibilty
Mon, Jan 28, 2008 at 6:08:27 PM
Multi Sloping Beam System
Fri, Mar 16, 2012 at 9:54:45 AM
Page generation time: 0.5532
