97 Users Online (96 Members):
Forums >> General Discussion >> Revit Project Management >> Question for metal cladding sheet as curtain panel attached to slopped roof
Hi all,
I have a question when building the warehouse. The exterior walls are metal cladding and I built they with profile curtail panel. They work perfect with rectangle wall. But the problem is I need them attach to the slop roof and they failed. Does anyone know how to solve this problem? I know there is a way I can pretend that I have metal cladding by using mullions but I want to know if there is a way to make it real metal cladding walls. Thank you so much!
You never want to model siding - use a material instead. This post is old but it still applies: https://www.revitcity.com/forums.php?action=viewthread&thread_id=17756 I checked out the steel select site to see if they still have the Revit textures and they do.
So model your wall with a thickness and apply a material. This will connect to the roof correctly and render correctly. For plan and section detail views, you can place your profiles.
Hey thank you for your answer! I've learnt that I could use custom mullions instead of curtain wall panels to attach to roof. ))
Corrugate / Profiled Metal Wall & Roof Cladding |
Thu, Sep 22, 2011 at 3:56:30 PM
Standing Seam Metal Roof Material |
Tue, May 19, 2009 at 9:58:48 AM
Timber cladding with occasional colored panel |
Wed, May 4, 2011 at 9:35:02 AM
Curtain Grid Question |
Tue, Jan 2, 2007 at 2:42:36 PM
HELP - How do I apply metal roof panel to my existing Roof |
Wed, Oct 8, 2014 at 10:37:02 AM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
