62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Section Family
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Hello everyone,
could anyone explain what a Callout Tag parameter in a Section Family is
thanks a lot!
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
The Callout Tag parameter in a section is there for if you are seeing the section called from a larger section.
Say you are in a wall section and you make a larger section detail in that view. The family will use the callout tag.
Plan details and section details can both be created in either an elevation/section or a plan so they need to have the 2 different tag options.
Thank you very much. This topic is not explained in Help. It would be great if you attached an image illustrating your explanation
The image below and this should help: https://gtu.ge/Arch/Faculty/Multimedia/Resources/Revit/Help/filesUsersGuide/WS1a9193826455f5ff662ffb11407b58d52-5bd3.htm
Thank you for the image. I think this topic has not been explained in Help, and i wasnt able to find anything about it in the Internet
section through in-place family? |
Mon, Apr 30, 2007 at 10:01:20 PM
Section cutting a family? |
Thu, Jan 11, 2007 at 3:30:49 AM
Masking Region in Section Head Family |
Wed, Apr 9, 2008 at 3:41:12 PM
13
Section through a family object and imported dwg file |
Fri, Mar 26, 2010 at 12:41:24 PM
Section problems |
Mon, Oct 3, 2011 at 9:56:55 AM
Members: | 2016882 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
