152 Users Online (151 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Add Vuew Scakes for Model Line Weights
Mon, Apr 5, 2021 at 12:02:10 PM | Add Vuew Scakes for Model Line Weights
glenlake
3.5 Stars: 3 Votes
Good morning everyone,
for adding a scale for line weights chart,
In Revit 2020, point 3 of Help suggests to "select a scale value, and click OK". I think it means "select from the drop-down list".
Is it possible to create columns for special scales, e.g. 1:125, or 1Blushing5?
Thank you,
Mon, Apr 5, 2021 at 12:08:50 PM | Add Vuew Scakes for Model Line Weights
glenlake
3.5 Stars: 3 Votes
was intended to be 1Blushing5.
The idea is to add a scale that is not predefined.
Thanks
Mon, Apr 5, 2021 at 2:43:49 PM | Add Vuew Scakes for Model Line Weights
To Add a Custom Scale to the Scale Drop-Down List
  1. Choose Options from the Application menu to open the Options dialog box.
  2. Select the User Preferences tab, and then click the Default Scale List button at the bottom of the dialog box.
  3. In the Default Scale List dialog box, click the Add button.
Fri, Apr 9, 2021 at 11:48:11 AM | Add Vuew Scakes for Model Line Weights
glenlake
3.5 Stars: 3 Votes
Thanks a lot!
Fri, Apr 9, 2021 at 11:53:02 AM | Add Vuew Scakes for Model Line Weights
glenlake
3.5 Stars: 3 Votes
Thanks a lot!
{It is soooo difficult to submit an entry here}
Fri, Apr 9, 2021 at 12:06:37 PM | Add Vuew Scakes for Model Line Weights
glenlake
3.5 Stars: 3 Votes
Sorry can't find it. I have Optios under File. There are UserInterface settings. Could you show a screenshot?
Detail Lines Follow Model Line Weights Problem
Fri, Sep 9, 2011 at 9:55:52 AM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:39 AM
Line weights with Custom Scales
Wed, Aug 16, 2017 at 12:09:54 AM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:33 PM
A Nice set of Revit Line Weights
Wed, Jun 20, 2007 at 8:47:37 PM
Page generation time: 1.7226
