42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Building Display Error - prior to crash
Fri, Apr 2, 2021 at 10:22:39 AM | Revit Building Display Error - prior to crash
MVBIMBRO
Several Revit Building 2019 and 2020 users in our firm recently (soon after installing windows 10 updates) started receiving the error dialog box below.  The text reads," An error has occured while drawing the contents of this window. This window shall be closed."  The screen then flickers and then Revit crashes without an opportinity to save.  It almost always happens when opening an Building Elevation view.  Mirosoft, AutoDesk, MicroDesk and our Tech subcontractor have never seen it before and are pointing to eachother.  Has anyone seen this?
Fri, Apr 2, 2021 at 2:39:00 PM | Revit Building Display Error - prior to crash
I have seen this before.  This may help you even though it was for a different release: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Revit-2017-crashing-during-start-up.html
Crash crash crash
Sun, Sep 18, 2005 at 4:34:13 AM
crash recovery
Thu, Apr 23, 2009 at 7:02:49 PM
Loading imported file crashes Revit 2009
Fri, Feb 13, 2009 at 9:13:33 AM
Sketchup imported into Revit Error and Crash
Wed, Nov 12, 2008 at 5:17:13 PM
Print Error "Display Error"
Tue, Dec 20, 2005 at 5:04:35 PM
Page generation time: 2.1648
