38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Help with Forms panel in Revit LT 2020
Mon, Mar 22, 2021 at 2:05:45 PM | Help with Forms panel in Revit LT 2020
72CJ5
I am using Revit LT 2020.  The help page and google searches all say that the ability to create solid or void extrutions is included in this version of the program. However I can not find it any where. I see this in the help file:
  1. Click in the drawing area, and draw a closed loop that intersects solid geometry.
  2. Select the closed loop.
  3. Click Modify | Lines tabForm panelCreate Form drop-down(Void Form). A void form extrusion is created.
  4. (Optional) Click Modify | Form Element tabForm panel(Solid Form) to convert this void to a solid.
The form panel and Create form drop down are missing from my ribbon all together. How do I get it to show up?
Thu, Mar 25, 2021 at 1:00:37 PM | Help with Forms panel in Revit LT 2020
marmiketin1
4.5 Stars: 10 Votes
What you have found is for Mass Elements which are a different thing than extrusions.
To create an extrusion in a project you go to Component --> Model in Place --> Void Extrusion.
Or in a family simply go to extrusion.
Trouble with void forms and parametrics in families
Mon, Jul 4, 2011 at 9:28:30 AM
revit 2013. curtain panel pattern based
Sun, Jan 20, 2013 at 9:11:10 AM
Need forms for a residential environment.
Thu, Mar 8, 2012 at 7:13:26 AM
I hope for tutorials on curved forms
Fri, May 14, 2004 at 4:09:17 PM
R 2020 - Empty CW Panel attach to roof ?
Mon, Oct 28, 2019 at 10:29:49 AM
Page generation time: 3.0850
