97 Users Online (96 Members):
Forums >> General Discussion >> Revit Project Management >> Revit Exporting to Autocad Changes the Justification and Margines of Texts
Hi all,I encountered a severe problem today exporting from Revit to AutoCAD (DWG).As shown in picture #1, in Revit all texts are in normal condition.Picture #2 shows AutoCAD DWG file made by Revit via EXPORT command.As seen comparing two pictures, the problem is changing the alignment of all Text (Mtext) objects to "Top-Left" ignoring the definition of Texts in Revit. Another problem is that changes in the margines of TEXT, wraps some MTexts in AutoCAD.Should any one can solve the problem?I apprecate any help or clue guiding me to study.
Looking at your images, I believe your problem is your text width. The individual text characters are wider in the autocad image and that forces the text to be split into two lines. See how you can change those settings.
Thanks a lot for your reply,
you are right. AutoCAD changes text objects in Persian and other languages in which some letters are attached to each other and fills between some of adjacent letters "kashideh". Unfortunately there is no way to prevent AutoCAD from doing this work.
Autocad text justification |
Tue, Apr 8, 2008 at 7:45:04 AM
Adding texts to a model |
Fri, Jan 6, 2006 at 3:53:42 PM
Trouble w/ exporting to AutoCad |
Thu, Jan 20, 2011 at 11:18:07 AM
exporting to autocad |
Fri, Aug 31, 2012 at 7:35:41 AM
Thu, Jun 20, 2013 at 1:24:08 PM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
