69 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Aligned dimensions on non-orthogonal walls
Sun, Jun 11, 2006 at 10:11:42 AM | Aligned dimensions on non-orthogonal walls
3DLake
Hello: I have a question on how to get the aligned dimension in this example to work. With Aligned dimension selected using points #3 and #4 gives linear dimension “A” With Aligned dimension selected using points #1 and #2 gives aligned dimension “B” With Aligned dimension selected using points #1 and #3 then MANUALLY moving the witness marks I can get aligned dimension “A” (which is what I am after). How can I get this to work right the first time? The help section in Revit 9 under linear dimensions suggests this should work. Thanks -Loren
Sun, Jun 11, 2006 at 11:36:40 AM | RE: Aligned dimensions on non-orthogonal walls
coreed
coreed Avatar
4 Stars: 16 Votes
this may not be exactly what you are after, but it may help shed some light on your situation link from Revit Oped blog http://revitoped.blogspot.com/2006/05/dimension-parallel-arc-grid-lines.html HTH Post edited on 2006-06-11 11:49:29
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Jun 11, 2006 at 8:16:12 PM | RE: Aligned dimensions on non-orthogonal walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
You just need to make sure you select the correct point the first time. You are able to do it manually by manipulating the witness makrs the second time because you are selecting the correct point the second time. Tab through until you have the correct point selected (which is easier said than done).
Hiroshi Jacobs
The Catholic University of America
Aligned dimensions for centering curtain wall door
Fri, Dec 23, 2011 at 6:26:41 AM
aligned acting like linear (up-down, left-right)
Tue, Dec 6, 2011 at 4:00:41 PM
Aligned dimensions
Wed, Apr 12, 2006 at 3:22:32 PM
Aligned Dimensions Shift While Moved
Mon, Dec 12, 2011 at 12:43:42 PM
Dimension aligned
Thu, Nov 17, 2011 at 9:49:28 AM
Page generation time: 1.2967
