78 Users Online (77 Members):
Forums >> Revit Building >> Technical Support >> trimming walls to underside of stairs
Had seen a procedure for this that seemed kind of involved.
All I do is ckick on wall and "edit profile" align the purple line defining the top of the wall with the bottom of the stair carriage.
Is this a vaild approach or should I anticipate some unforeseenproblems down the road as the model progresses
The involved process you speak of was regarding attaching a curved wall to curved stairs.
rather than edit profile, i just draw a reference line at the same angle as the stair and then attach the wall to this...
Thanks, do you anticipate any problems with just editing wall profile.
I'll try the refence line. Have I got it right that you'd be able to attach the reference line to the carriage resulting in a wall that updates as the stair carriage is moved around.
No.
Don't believe you'll be able to constrint the reference plane/line to the stair though...
Thanks for your input.
Attaching walls to stairs |
Tue, Aug 22, 2017 at 12:20:10 AM
13
Trimming Walls to a slope |
Fri, Feb 24, 2006 at 2:57:04 PM
Attaching Curved walls to underside of Curved Stairs |
Wed, Sep 12, 2012 at 12:43:47 PM
Attaching walls to the bottom of stairs |
Wed, Aug 24, 2011 at 10:15:55 AM
cantilevered stone stairs |
Thu, Feb 22, 2018 at 2:30:39 PM
Members: | 2017185 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
