Forums >> Revit Building >> Technical Support >> Revit Hatch Pattern w/ alternating masonry courses?
Maybe this is simple but I'm not getting it to work. I'm trying to get 2 courses of 24x12 and then a single course of 24x8 below that, then repeat.
To start it, I was just trying to get the individual courses setup with the below. I know (at least part) of the issue is that both patterns are starting in the same location, when I need the 24x8 to start after 2 courses of 24x12 above. Can you do that in a pattern file, or do you need to arrange continuous DASHED lines to make this work? Any help is appreciated (Revit 2020). Thanks!
*ALTERNATING BRICK PATTERN
;%TYPE=MODEL
0, 0, 0, 0, 12
90, 0, 0, 12, 12, 12, -12
0, 0, 0, 0, 8
90, 0, 24, 8, 4, 8, -8
Here is the pattern that should be used.
;%UNITS=INCHES
* Double 24x12 Single 24x8,
;%TYPE=MODEL
0, 0,0, 0,32
0, 0,12, 0,32
0, 0,24, 0,32
90, 0,0, 0,24, 12,-52
90, 12,12, 0,24, 12,-52
90, 0,24, 0,24, 8,-56
90, 12,32, 0,24, 12,-52
90, 0,44, 0,24, 12,-52
90, 12,56, 0,24, 8,-56
Edited on: Tue, Nov 17, 2020 at 2:13:44 PM
The pattern can be made a little simpler by using this.
;%UNITS=INCHES
;%TYPE=MODEL
0, 0,0, 0,32
0, 0,12, 0,32
0, 0,24, 0,32
90, 0,0, 32,12, 12,-52
90, 12,12, 32,12, 12,-52
90, 0,24, 32,12, 8,-56
Edited on: Tue, Nov 17, 2020 at 2:39:01 PM
Alternating Course Hatch Pattern - Arch2008 |
Fri, Jan 11, 2008 at 11:05:56 AM
half course masonry hatch pattern |
Thu, Jan 25, 2007 at 12:17:55 PM
Source for a hatch pattern |
Thu, Apr 5, 2018 at 2:38:48 PM
Aligning hatch pattern on elevations |
Thu, Mar 6, 2008 at 9:11:59 AM
CMU HATCH - ALTERNATING 8" AND 4" BLOCK |
Wed, Sep 23, 2009 at 4:03:33 PM
Members: | 2017191 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
