Forums >> General Discussion >> Revit Project Management >> Hello, please can somebody help with model views. Keep losing my model.
Hello, hope everyone is well.
Please could I kindly ask for some help, as really struggling on this project.
My Revit knowledge is limited, but I get by okay, I mostly just do house extensions, so usually just have one central house model, then add phases for the extension part (like a before and after method).
On this project, I am really struggling, as keep loosing my model?? When I switch to a 3D view, it’s just not there, then I have to scroll and find it (sometimes have to use the little lightbulb at the bottom to pin point the house, then scroll in wildly to reach it.
I have tried to centre the pivot, but as soon as I go to the 3D cube, the model vanishes again?
I never had this issue before, and any kind help would be so appreciated. Thank you
This sounds like you have some model elements out in space that forces your 3D view out to an extreme size. Turn on all worksets and categories in this 3d view then window, one at a time, the corner areas of your screen to see what elements you might find.
Edited on: Sun, Nov 8, 2020 at 12:23:37 PM
Edited on: Sun, Nov 8, 2020 at 12:32:45 PM
Ceiling Plan tags in Linked Model Views "Moving" (2010) |
Tue, Dec 21, 2010 at 7:20:59 AM
model views to new file |
Mon, Jun 23, 2014 at 7:06:26 AM
Copy model? |
Fri, Nov 24, 2006 at 6:35:28 AM
Converting Model Views to Drafting Views |
Fri, May 13, 2016 at 2:13:30 PM
Linked Model - Losing only some doors from linked model |
Thu, Oct 21, 2010 at 1:52:15 PM
Members: | 2098140 | Objects: | 23164 | Forum Posts: | 152291 | Job Listings: | 3 |
