77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Family Line weight Control.
Thu, Nov 5, 2020 at 12:13:10 AM | Family Line weight Control.
PsymonMKII
PsymonMKII Avatar
I have a project with a casework family I have made loaded into the project and the cut lineweight is too thick.
When I change the casework cut lineweight in object styles it does not change the family.
Thanks I have checked:
  1. The family has nested parts. All of the parts are "Casework" families
  2. I have not made any of the parts subcategories.
  3. The view does not have a visibilty / graphics override applied to it.
The random thing is that the object style has lineweight 2 assigned to the cut linetypes, as mentioned changing the cut lineweight doesn't do anything.
However if I change the thickness of Lineweight 5 in "Lineweight" under additional settings, it changes the cut thickness of the family.
Nowhere can I see that lineweight 5 is assigned to casework cut styles.
Where would it be assigned this lineweight? Why is it happening?
Edited on: Thu, Nov 5, 2020 at 12:16:49 AM
CAD Manager
Using Revit since 2006 with a ten Year Break. Last version was 2009
Revit 2019 - 2021
Thu, Nov 5, 2020 at 8:21:47 AM | Family Line weight Control.
marmiketin1
4.5 Stars: 10 Votes
In the project go to Manage Tab --> Object Styles --> Casework, then expand and change the linetype weight for the lines you want. This must be done in project. If a linestyle/type is created in a fmily and the family is loaded into a project that linestyle/type is loaded into the project as well. Once that happens the project version of the line will override any changes you may have made in the family itself.
Thu, Nov 5, 2020 at 4:17:51 PM | Family Line weight Control.
PsymonMKII
PsymonMKII Avatar
Yeah,
I undertsand that - but that does not change the object in cut view.
I have opened the project, picked the casework family - opened it for editing and then loaded it into a new blank template family. The casework family then behaves as it should, so there is some override that has somehow transposed the lineweight value or made the lineweight assignments changed in that particular project.
I also noted that if I change the lineweight 5 under additional settings it changes other objects that it is not assigned to like windows. Is there a global lineweight override for cut objects in a view?
Is there somewhere else other than object styles or visibility graphics overrides that affects lineweight?
CAD Manager
Revit 2019 - 2021
Thu, Nov 5, 2020 at 4:27:09 PM | Family Line weight Control.
PsymonMKII
PsymonMKII Avatar
OK Fixed it. Don't know what the problem was. I think the use changed something but I don't know what. I transferred project standards from the template and it fixed it.
Weird.
CAD Manager
Revit 2019 - 2021
Line Weight as Family Parameter
Fri, Mar 16, 2007 at 4:23:58 PM
Making Line Weight a Parameter?
Mon, Mar 19, 2007 at 1:59:55 PM
Line weight control
Tue, Nov 21, 2017 at 2:14:39 AM
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:29 PM
Line Based Family For Control Joints
Tue, Sep 29, 2015 at 12:27:27 PM
Page generation time: 1.3834
