58 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> I cannot grip a wall in my model
Wed, Oct 14, 2020 at 2:52:19 PM | I cannot grip a wall in my model
wilray
I have a model that was started by a coleague in my office. I can work with every item in the model except or 5 basement walls. They will not allow me to grip them to hiighlight them at all. How can i fix this? My coleague can still work with these walls.
Thu, Oct 15, 2020 at 7:54:51 AM | I cannot grip a wall in my model
hanbyjm
Check the view range of the view you are tryiing to grab them.  Can you grab them in other views such as the 3D view?
Tue, Oct 20, 2020 at 12:23:47 AM | I cannot grip a wall in my model
noraadam800
This same issues iam facing also can you help me ?
Tue, Oct 20, 2020 at 7:54:04 AM | I cannot grip a wall in my model
When a user borrows elements, or has them checked out, no other users can borrow those elements until the borrower synchronizes with the central model. When they attempt to make those elements editable or try to modify them, they receive an error. If a user would like access to those elements, any changes made to those elements must be saved to the central model and the borrower must relinquish them. If you need the elements, you can place an editing request to inform the borrower or communicate directly with them by using the Communicator.
In addition to borrowing elements, users can check out an entire workset. Then, no other user can borrow elements in that workset. If another user is listed under Borrowers for a workset, you can still become the Owner of that workset. When you become the Owner of that workset, you still cannot edit the elements in the workset that are checked out until they are relinquished. You are the owner of all other elements in that workset, though.
reference plane wont 3D. stuck marking 2D
Thu, Jun 23, 2016 at 7:48:37 AM
How to make grip handles show in elevation but not plan
Tue, Sep 25, 2018 at 11:00:01 PM
elevation bullets handle
Wed, Jun 8, 2016 at 12:37:43 PM
Elevations/sections rotate grip control to re-align to skewed (rotated) walls
Mon, Aug 12, 2013 at 12:25:51 AM
Snap using instance parameter grip
Thu, Mar 5, 2009 at 11:04:47 AM
Page generation time: 21.6271
