78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> DIMENSIONING
Fri, Jun 9, 2006 at 11:29:11 AM | DIMENSIONING
BRIANDHADLEY
1 Stars: 1 Votes
WHEN I DIMENSION USING INDIVIDUAL RERERENCES WITH FACES OF CORE PICKED THE DIMENSIONS STILL SNAP TO WALL FACES. HAS ANYONE ELSE HAD THIS PROBLEM AND HOW IS IT REMEDIED.
Fri, Jun 9, 2006 at 11:42:55 AM | RE: DIMENSIONING
TomDorner
4.5 Stars: 25 Votes
If all the layers of your wall are defined as being in the core, then the wall face and face of core are the same. Do you have walls with a non-core layer? Also, if the non core layer is very thin as in 1/2" GWB, then it may look like the face of wall is what is being dimensioned to. To check, set view to larger scale, set view to medium or fine and turn on the thin lines mode. Zoom into dimension in question and take a look. HTH Tom
Fri, Jun 9, 2006 at 1:25:26 PM | RE: DIMENSIONING
BRIANDHADLEY
1 Stars: 1 Votes
I DO HAVE LAYERS OUTSIDE THE CORE. I AM ALSO POSITIVE THE DIMENSION IS SHOWING TO THE WALL FACE. I AM BAFFLED.
Sat, Jun 10, 2006 at 12:48:10 AM | RE: DIMENSIONING
hisdirt
5 Stars: 5 Votes
Have you tried hovering the cursor over the wall edge and pressing tab to cycle through the layers of your wall? And when you type, do you realise that the caps lock is on?
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:56 PM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:58 AM
Dimensioning and then hiding objects?
Wed, Nov 7, 2012 at 2:34:02 PM
Isometric Views and Dimensioning
Mon, Feb 22, 2010 at 3:20:23 PM
Dimensioning railings
Fri, Jul 24, 2009 at 3:04:01 PM
Page generation time: 0.1985
