74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Roof Issue
Thu, Sep 10, 2020 at 4:16:33 PM | Roof Issue
McNut007
I am using Revit 2019 and trying to do a roof.  It is a gable roof with a small hip at the top.
Fri, Sep 11, 2020 at 7:12:18 AM | Roof Issue
You should be able to do this with a single roof sketch.  On those 'hips', break the sketch at the ends of the hip and add a roof slope dfining the hip slope.
Fri, Sep 11, 2020 at 7:48:58 AM | Roof Issue
McNut007
thanks.  is thereba video showing something like that or simular.  I am somewhat new to revit and roofs seam to give me a hard time.
Fri, Sep 11, 2020 at 8:11:40 AM | Roof Issue
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I don't have a video, but you can download this file and reverse engineer the roof.
Fri, Sep 11, 2020 at 1:51:36 PM | Roof Issue
McNut007
Thank you.  That is most helpful.
Fri, Sep 11, 2020 at 2:02:58 PM | Roof Issue
Please post your working roof sketch so others can learn from it.
Edited on: Fri, Sep 11, 2020 at 2:03:28 PM
Fri, Sep 11, 2020 at 3:08:44 PM | Roof Issue
McNut007
For some reason, the hip is not working.  Even though I have broken the hip to make it smaller.  It still shows up as a full hip.  Where am I going wrong.  Attached is the roof file.  Any guidence would be appreciated.  Thanks
Fri, Sep 11, 2020 at 3:28:43 PM | Roof Issue
Did you add the slope to the end of the hip in the sketch?
Fri, Sep 11, 2020 at 4:00:53 PM | Roof Issue
McNut007
Yes.  At the Gable end with the small hip.  I have the two outside lines as "No defined slope".  The center were the hip is.  Has a defined slope of 6/12.
Fri, Sep 11, 2020 at 7:43:32 PM | Roof Issue
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
For starters, make two side line segments equal length and apply an offset for the middle segment (pic 1).
If you make those segments too short or the offset too high, Revit could complain. In that case try the option with two roofs (pic 2).
Sat, Sep 12, 2020 at 1:55:05 PM | Roof Issue
McNut007
Thank you very much.  Your image was very helpful.
Sat, Sep 12, 2020 at 2:09:43 PM | Roof Issue
McNut007
Attached is the part of the roof I was needing to make.  Thanks again.
Roof Joining Issue
Fri, Jan 4, 2013 at 2:37:39 PM
Roof by Face on curved mass surface issue
Mon, Oct 5, 2015 at 12:39:59 AM
Linestyle Display Issue
Tue, Jan 25, 2011 at 8:57:10 AM
Additional Roof will not attach to original roof
Fri, Jun 7, 2013 at 7:56:41 AM
Roof Slope Issue
Tue, Nov 10, 2009 at 9:00:22 AM
Page generation time: 0.7275
