90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg.
Wed, Aug 19, 2020 at 7:59:04 AM | Incompatibility between ''Bluebeam'' pdf fillar and Autocad dwg.
giovanni22
Hi!
I would like your opinion about a problem I have seen a couple of times with pdf files  (made with  ''Bluebeam'' on top of pdf files I have sent), that colleques of mine sent to me and the consequent dwg file I have after I have inserted the pdf file in Autocad in order to save as a dwg.
All the new design that my colleques have made (with ''Bluebeam'') disappears and on the dwg file I have only the old design which I sent to them.
The strange thing is that on the preview (When I insert the pdf to  the Autocad) I can see all the project made with ''Bluebeam'' but on the dwg there isnt anymore.
Is there something I forget to do during the changing process from pdf to dwg or is it a known problem also to others?
Is there a way to solve it?
Thank you.
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:20 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:47 AM
Can't figure out PDF printing. Help!
Tue, Sep 12, 2006 at 4:39:08 PM
pdf selections
Sun, Oct 22, 2006 at 3:24:53 AM
Autocad imports PDF's. Is there anyway Revit does that?
Mon, Feb 1, 2010 at 5:06:19 PM
Page generation time: 0.8263
