123 Users Online (122 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> snap
Fri, Jun 9, 2006 at 3:58:00 AM | snap
Will9000
4 Stars: 5 Votes
Is there a way that we can change the object snap settings when drwing a wall in revit, my wall is not true horizontal and it wont leae me pick the points i want any suggestions would be great Will
Mon, Jun 12, 2006 at 11:21:30 PM | RE: snap
goum
Have a look under, Settings - "Snaps". this lists the options for snap settings. If the wall you're drawing is snapping to a non-preferred point try using the "tab" key to alternate between snaps until the preferred point is reached. You can also use the "hot keys" for each snap point listed under the snap settings.
GN Brisbane, Q Australia
I can“t snap beam on grid lines
Fri, Dec 29, 2017 at 4:33:07 AM
Can not snap to linked files
Wed, Oct 31, 2012 at 5:42:48 PM
Can't snap to furniture in revit
Fri, Jan 27, 2012 at 9:02:35 AM
How to snap in 3D (not be constrained within current work plane)
Sun, Jan 27, 2013 at 12:51:47 PM
On sheet: cant snap to frame of drafting views
Thu, May 19, 2016 at 2:59:03 PM
Page generation time: 0.1944
