88 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Door tag placement??
Thu, Jun 8, 2006 at 11:44:11 PM | Door tag placement??
ICON
5 Stars: 3 Votes
I've created a door tag that displays the size for my interior doors and I'd like to predetermine the tag's placement which would be governed by the position of the door slab on the floor plans. Tag looks like "32" x 84". I'd like the tag to align itself with the door panel so that the tag appears to be parallel to the door panel. This will allow me to intuitively place other information out of the way of the tag. The preferred placement would require the tag to run horizontally in some cases and vertically in others, depending on the position of the door panel in the plan. I suppose that it may have to also place at a 45 degree angle as well.
Revision Cloud - Tag on placement??
Wed, Feb 20, 2013 at 8:44:05 AM
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:39 PM
Page generation time: 0.8051
