89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> printing problems in Revit 2013, windows 10
Wed, Jun 17, 2020 at 2:54:36 AM | printing problems in Revit 2013, windows 10
vnd
3 Stars: 2 Votes
Hi,
Does anyone have tech support advice about printing to pdf problems in revity 2013 for windows 10? Basically the print window opens but none of the buttons work to set print setup.
any help would be appreciated.
VND
Wed, Jun 17, 2020 at 5:55:57 AM | printing problems in Revit 2013, windows 10
Look at your pdf program that you use - that is probably your problem.
If this is a new problem, then maybe that just needs to be re-loaded.
Look at a different pDF program.
Fri, Jul 3, 2020 at 3:08:02 AM | printing problems in Revit 2013, windows 10
vnd
3 Stars: 2 Votes
thanks, got it sorted shortly after it began to work again.
VND
Revit Print Problems - UPDATE
Fri, Sep 2, 2016 at 1:44:14 PM
Printing
Thu, Jun 14, 2018 at 12:59:05 AM
Revit Structure 2013 windows 7 & windows XP Compatibility
Wed, May 15, 2013 at 1:27:11 PM
Graphic problems while in 3D Realistic view in 2013
Tue, Sep 25, 2012 at 4:10:42 PM
Revit 2013 and Windows 8
Thu, Dec 12, 2013 at 12:27:02 PM
Page generation time: 1.6989
